BLUF - I am looking for recommendation on a water-based stain that approximates an oil-based Minwax "Red Oak" stain.
The long-version
Hello all, I've been offline for a while as other home renno/resto projects and responsibilities have demanded my attention. As is becoming the norm, the weather turned from hot humid St. Louis summer almost directly to what passes for St. Louis winter here - cold/grey/wet - so I did not get much time to do any projects that require leaving the windows open to air out the house. This means that I can't easily finish trim (or much of anything) using oil based stains. so I am exploring water-based stain options for my interior trim and I am looking for some advice on achieving a desired finish.
The project is my house's interior trim.
After giving up on what remained of much of the mangled douglas fir that makes up my home's 102-yr old trim, I've opted to use southern yellow pine (SYP) which has a similar well-defined grain pattern. I can get fir locally, but it is prohibitively expensive for large projects like creating new and replacement trim for my home.
After some experimentation, I was able to achieve a finish very similar to well-kept 100-yr old shellaced fir using a basecoat of a bright "fiesta orange" minwax stain with a top coat of minwax "red oak"
Here is a test installation in my kitchen (yes I know that the top rail framing the tile isn't joined to the casement properly - the rail is a temporary placeholder. if you are curious, those grooves in the wall are the browncoat of a replastering project - which I also had to pause due to the change in weather).
SYP is historical appropriate for a house of my vintage. It is also significantly harder than the "clear" pine that's been locally available and it takes stain better than any "pine" I've bought from a big retailer in the last 20 or so years. That I've been able to get clear SYP from Lowes continues to boggle my mind. This is pushing me to get as much work done as I can before SYP vanishes from the stores for another 20 years...
So, back to the staining question. I've also been able to get a pretty good result using a water-based "general finishes" orange dye stain with a topcoat of minwax red oak.
The problem is that I can't find a water-based Red Oak or equivalent color. The "General Finishes" "Sedona" water-based stain looks similar to the end-state color I am going for. I will be experimenting today with some scraps, but I suspect that I won't get the orange-red color that approximates 100-yr old shellacked douglas fir - even with amber shellac.
I was at my local Rockler and Woodcraft stores yesterday and they couldn't give me a solid suggestion. I am more than willing to experiment, but water-based stain is very expensive ($20-$25 for a pint). The water-based "red mahogany" sample at Woodcraft was significantly more brown than I wanted.
So here are some bottom-line questions:
1) Can someone give me a suggestion of a water-based stain that could give me a good red oak approximate?
2) I am largely inexperienced with water-based stains. Is there an additive like a "trans tint" or other product that I could add directly? If so, what color? Like the water-based stains, trans tint is also very expensive, so I cannot afford to buy a lot of colors to experiment with.
3) Can someone recommend a good book or other resource to learn more about water-based finishes?
The long-version
