Most plans will include a cut list, but how many of us actually use it to our best advantage?
There has been a lot of discussion lately about accuracy, which is important but not a critical as repeatability which can only be accomplished by setting a fence or stop once and making every cut of that dimension.
Don't try to break a large sheet down cutting the parts to the required size, cut them a bit larger, then when all the parts are cut set up your table saw fence or stop to each dimension and go through the list for each dimension which will result in every required part being exactly the same same length and width.
