Even though my fence and blade is parallel on my table saw, I get a small belly in the middle of the cut. How can I fix this
I got a 80 tooth blade, it cuts smooth edges. I'm currently making beekeeping frames and after straightening the side of the wood that will be on the fence after 2 or three passes you can see the wood moving away from the fence ever so slightly till it become a wide opening after it passes the bladeWithout being there and seeing what's happening, to fix it simply saw in from each and to the center until the kerfs meet and separate it into 2 pieces.Even though my fence and blade is parallel on my table saw, I get a small belly in the middle of the cut. How can I fix this
A 40 tooth blade will give a nice smooth surface and still rip reasonably well.
A 50 tooth will do about the same, so either one.
I wouldn't use a 60 tooth for ripping.
I would recheck the distance from a marked tooth to the miter slot and verify the fence is spot on parallel to the same miter slot.
