Hello, hope this post is in the appropriate forum...was wondering if anyone could give me some advice/opinions about setting a 4x6 pressure treated post in the ground...Any thoughts are appreciated!
Hi Gus,
Looks like your already well into this project and have little to do than get it into the air?
I will assume you are just following standard "web base" plans for generic bat houses also.
I will add to others advise here..
.NO CONCRETE!!!..it will last longer and be more secure with just well packed rock and gravel around its base.
You can also extend the life span of the PT wood by charring the outside portion that goes into the ground and there are also "borate" and/or decay inhibitor "pills or plugs" that can get drilled into the wood at a later date should you wish or need more protection. PT wood is not as "rot resistant" in many of its forms as it is advertised by the manufacture.
If your design for the Bat House doesn't work as intended, don't hesitate to come back here for more assistance or drop me an email. I'm no longer an active member of
BCI (Bat Conservation International) but once was in a professional capacity. Should you want to look at other examples of bat houses, check out
"Chiroptera Architecture," for some ideas...I update it once or twice a year...<img src="http://www.woodworkingtalk.com/images/WoodworkingTalk_2016/smilies/tango_face_smile_big.png" border="0" alt="" title="Laugh" class="inlineimg" />
Good luck!
j
