Hello everyone,
I am a newbie to wood working and I have a question about squaring up a miter saw. I recently bought a Ryobi TSS102L 10inch sliding miter saw for a dollhouse bookcase I want to build for my daughter. I started cutting a couple of pieces and I noticed that the cut that the miter saw makes is not completely square, it started out straight but by the end of the 12 inch board I was cutting, the cut had veered off from the line I had made by a few milometers. I checked the saw blade against the fence and the blade itself for a square and I found that both were square according to my metal carpenter's square. Upon reading different forums, I found that the issue I was encountering was a common one with Ryobi miter saws, in that the 0 degree miter catch was not actually 0 degrees. I have fiddled around with the manual degree handle and have gotten the cut only 1 mm off. My question is should I continue to see if I can get it perfect, or will 1 mm not really affect the overall design of the bookshelf? I do not want to return it, but I will if I have to. Thanks,
Ryan
Ryan
