Query: Is it possible to slow down a bench grinder
22K views 44 replies 14 participants last post by  School Bully
#1 · (Edited)
I inherited an old but very good condition, 1/3hp Baldor Model 612, two-wheel bench grinder from my late father. The motor, wired for 125VAC, runs at 3600 RPM, which for my personal use is way too fast. Half that speed would be much better.
Can anyone please advise me: (1) Is it possible and practical to reduce the speed of the motor without damaging it?
(2) How might I go about it?
I'm not an electrician but have some knowledge of electrical circuitry, can read simple schematics, and have built small projects over the years.
Nope!
You can not change the speed of an induction motor using a "variable speed controller" as you would on a router which is an AC/DC brush type motor. Unless the motor has internal windings that allow for two speeds, you are out of luck. The standard RPMs for induction motors are 3450 and 1725 RPMs. However, bench grinders do come in both speeds. It is for this reason that I do not sharpen my plane blade or chisels on a 3450 RPM grinder, it gets the metal too hot too fast. I use a belt sander with a "belt drive" which I can change the speeds by moving the belt on a step pulley. A direct drive bench grinder has no such feature.
Reactions: NoThankyou
Try to slow that one down, and you will burn it up. It has a centrifugal start switch that will switch on the start winding if you succeed in slowing it that much, and the start winding will quickly overheat and burn, since it isn't rated to be on more than a few seconds at a time. Induction motors are power line frequency dependent to govern their speed. You need to change the power frequency to change the speed, but again, look out for that start winding. They make power controllers for 3 phase induction motors to vary the frequency of the power going to them, and this will allow changing the speed, but slow the motor too much under load, and the motor won't be able to cool itself.
So, in short, don't try it. If you do, you will burn it up.
Nice grinder. Leave it alone and enjoy using it at it's intended speed. Buy another grinder designed to run slower, if you need that.
Charley
#7 ·
Gentlemen: Thank you all very much for your helpful replies. You've saved me some grief, not to mention Dad's grinder. I can see this Website is going to be useful and enjoyable.
Although Baldor no longer makes the grinder in question, a Wyoming distributor of my acquaintance still had the factory documents on its Website so I was able to download the motor schematic last night. From that, I could see the motor is an induction unit with a capacitor start and a drop-out relay instead of a centrifugal switch.
After your timely warnings about what would happen if I reduced the voltage to the motor and the futility of altering the current frequency, I wanted to find out the grisly reasons so went to Quora and had it explained to me in grisly detail by a couple of E.E. types.
I'll still use the grinder for metal work but my chisel and plane blades will not go near it.
Stay well, all of you.
Bill
#18 ·
"It is not designed for capacitor start motors." You missed reading this statement in your link.
This speed controller will work fine on universal motors, like those in an electric drill, but they will not properly vary the speed of an induction motor whose speed is controlled by the power line frequency. Also, if you reduce the voltage of an induction motor to the point where it is no longer following the power line frequency, you will have lost most of the torque of the motor. Slowing it will also cause the centrifugal start switch to engage the start winding and capacitor circuit, which is not designed to operate for more than a few seconds at motor start-up. This will result in the start winding and capacitor being destroyed (you will let the magic smoke out).
Charley
JayArr is correct - my Baldor grinder is based on a capacitor start motor. Although I've taken apart, repaired and reassembled the Leeson Ph1 1.5hp TEFC motor Delta furnished with my tablesaw in 1986, I wasn't sure of the nature of this Baldor motor because it didn't have the usual external lump where a start capacitor would reside. It wasn't until I got hold of the motor schematic (attached) that I could see it was a capacitor start induction motor.
I am nobody's expert on electic motors and I was really fascinated to see how the start circuitry was designed, using a relay that is sized and calibrated to energize the start circuitry when the main winding draws peak current on startup, and then drops the start circuit out as the current draw falls when the motor approaches running speed. The centrifugal switch on my Leeson is a nice piece of work and I'd guess expensive and difficult to scale down below a certain mass. At a guess.
#13 ·
Well, I think I've made a start on understanding how it works. Let's see. Please check me on this: This is a split phase motor, the auxiliary winding consisting of relatively thin, high resistance, low inductive reactance wire, the obverse of the main winding. The two windings are initially in parallel. I don't understand what a "traveling wave" is but the phenomenon apparently serves to create enough torque to start the rotor moving, albeit the torque created is much less than what a capacitor-based start circuit can create. As the rotor approaches running speed and current draw diminishes, the auxiliary winding is dropped out of the circuit by either a centrifugal switch or a current-reading relay. From what I have read and think I understand, split phase motors would be used in low-torque applications like my grinder or a fan, say.
Pass? Barely Pass? Fail? Clueless?
Thanks,
Bill
The Baldor 612 was the bottom of the Baldor line. Even then, they were sweet little grinders. Very smooth and quiet. Much better than the Asian made stuff offered for cheap today.
If you're having burning problems using a 3450 rpm grinder, you need better instructions on using a bench grinder. One can burn on the slow speed grinders as easily as a high speed grinder.
Bob,
Probably it's my age - I'm slower these days to deal with things that happen fast. Other than for dressing cut machine screws and smoothing edges of sheet stock, I had thought to use this grinder for squaring up a worn chisel or plane blade before putting a new edge on it by hand with stones. I've done that with slow grinders in the past and was able to keep the blade sufficiently cool that it didn't draw the temper. With the help of other members I've now come to understand Dad's grinder is a one-speed pony, which is o.k.
I'd be happy to learn from any wisdom you'd care to impart. With only a few exceptions, I'm almost completely self-taught and that is what makes this forum especially useful and enjoyable.
Bill
#17 ·
The Baldor 612 is still listed with MSC for $456.39 so that's the potential quality level grinder you're putting together. I've bought many over the years for $20.00 from sellers that thought the 612 was the same as an Asian-made cheapie.
https://www.mscdirect.com/browse/tn...oduct_id=09010042&gclid=EAIaIQobChMIzvLk3PvY6QIVB9bACh1WAgG7EAQYASABEgJuPfD_BwE
The problem with the 612 isn't the grinder, but the tool rests. They are too light and flimsy for such a good grinder. I'll make my own out of thicker steel. Heavier tool rests make all the difference in the world. Add a few Kipp handles, and you've got a lifetime of convenience.
An 1800 rpm 6" grinder is incredibly slow in removing metal. I hate them. The trick is light quick passes. I can make 100 light passes on a plane iron or chisel in about 60 seconds. Keeping the stone clean and sharp is another key detail. Cheap stones aren't worth the trouble. They clog and heat too easily. By holding your fingers close to the cutting edge, you can feel the heat building so you know when to back off. The little rocks in the wheel only stick out so much so that's about all you can remove. To quantify with numbers, a light quick pass will remove about .001" to .0005" of steel. 100 light quick passes removes a lot of steel. Once the edge is formed, the steel goes right to the sharpening stones for sharpening.
Below are some shots of the 612s I've done over the years showing the tool rest components that I've remade. I hope these will offer some inspiration. Sharp tools are a joy to use and a properly rigged Baldor 612 grinder will offer a faster and easier way to get there.
Bob, Thanks for taking your time to help me along. I can see you've put some serious beef in those tool rests. I've noted that what I have assumed to be the original rests are pretty light and awkward and don't want to stay in adjustment. I particularly appreciate the photos that illustrate the mods you made. I'm not much of a metalworker but I think I might be able to replicate what you've done.
I can't identify for certain what wheels are on Dad's grinder except to say one is coarse and one is less so. I note that yours is set up with a wire wheel and a single stone. Do you use this setup for a particular purpose? Also, if you'd care to do so, recognizing that the primary purpose of my machine would be to sharpen edge tools, what brand and grade of wheels would you recommend?
Also, almost forgot: Do you find it advisable to dip the tool in water as you grind or just use your fingers to feel for excessive heat?
Thanks,
Bill
#20 ·
Bill, I think those inside wheel guards on your grinder are cast iron. I’m envious. The later versions were cast aluminum.
I always keep a water pot and wiping rag near by when grinding. Grinding is a hand activity and errors in pressure and pace can and do occur. About 100 passes in 60 seconds is a good pace I’ve found. Light and quick. Your fingers will tell you when the heat is rising in the blade. Sticking a wet blade into the wheel introduces contaminates that gum up the surface of the wheel and makes the wheel heat more than it should. Adages referring to the tedium of grinding are very true, but the results are worth it. The grinder shapes. Sharpening is done on stones.
That setup on the 612 with the wire wheel was something I fixed up for the basement shop area when I needed a wire wheel. I got the grinder without wheel guards, a $15.00 buy at a flea market. I had an extra set of wheel guards in stock. I’ve got well over a dozen types of bench grinders I’ve accumulated over the years. I grind my own shaper steel profiles for slip knives. A handy cut-off wheel for your grinder is a Norton A60OBNA2. No other wheel is as good or as safe. For your amusement, I’ll link a thread below.
http://www.owwm.org/viewtopic.php?t=56115
Try using the wheels you’ve got for the immediate future. Those $100.00 CBN wheels won’t be much different right now. The kind of wheel can make a little difference, but what makes a BIG difference is the condition of the abrasive on the surface of the wheel. You need two things; a diamond (1/4 carat) wheel dresser and a star (Huntington #0) wheel dresser. These are long term investments that will last decades. The diamond dresser scrapes all of that mess off the surface of the wheel and trues up the wheel for very smooth running. It also makes a mess so wear a dust mask. While the diamond cleans and trues the wheel surface, it also dulls the exposed abrasive granules. That new, clean surface will burn like crazy. The next job is to beat the dulled abrasives off the surface. Take the star dresser and press into the wheel’s surface while moving side to side. The pressure should be hard enough to almost push the grinder around on the bench. Again, more mess. The duration of the star dresser use should be about five seconds and that’s it. You’ll be amazed at the difference. Once the diamond has been used, try grinding something and observe the few sparks generated. Try the same piece after the star dresser and you’ll be amazed at the amount of sparks generated and how much better the wheel cuts. You need both tools to get a good job. The diamond cleans and trues the wheel and the star dresser restores the sharpness. When the wheel’s abrasive gets dull, a few seconds with the star dresser cleans things up. You’ll use the star dresser much more often than the diamond. If you read on the internet that a diamond is all you need, disregard that source of information.
The below photos are from a 2004 catalog so the prices will be a little different but not a whole lot. There’s no need to spend a pile on the diamond dresser.
#30 ·
Bob, I've ordered the Desmond star dresser you recommended. MSC carries it and they've been reliable. There has been a little inflation - twenty bucks instead of twelve. I tried at first to include a diamond dresser in the order. However, none of the single point tools MSC listed (that I could find) had handles on them. I wound up buying a "shop grade" quarter-carat dresser on an 8" shank and plastic handle, from Penn Tool Co. for about $28.
Big Brown is supposed to get them here in about a week. I look forward to trying them out and I've already figured out to do this on my driveway with a mask, to avoid adverse comment from the War Department.
#21 ·
Bob, Thanks very much for your extensive reply. I'll take your advice and work with the wheels that are already installed on the grinder, at least until I have a much better grip on technique and wheel maintenance. I'm going to lay in the accessories you mention and see what I can do with them. I'll report back - either progress or a cry for more help!
As I understand what you recommend, in the process of sharpening I should use the machine to establish a square edge and eliminate chips, then switch to stones. Should I set the tool rest for the bevel angle for the particular tool? e.g. 25 degrees for a low-angle block plane? I would guess so, but thought I'd better ask.
Best,
Bill
PS I've got some old tools from the bottom of Dad's barrel that I'm going to work with before I risk my small inventory of good stuff!
#22 ·
You understand it correctly about shaping on the grinder. It will take all day shaping with stones. I just checked tool pressure by pressing down on a postal scale. Wheel pressure should be about 1 ounce. Very light. As to angle, whatever looks about right will work. Once the edge has its burr off and honed sharp, the exact angle is not all that important. Hair shaving sharp is what you want, obviously. Initial shaping of a beater chisel or abused hand plane iron will seemingly take forever but it won't. Time it and you'll see. Once you've got the shape on an edge, restoring it generally takes just a few minutes.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390485&thumb=1
A piece of 1/4 ply works good at keeping an index of tool rest to wheel ratio.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390487&thumb=1
Kipp handles and custom made tool rest holders (from angle iron) on a 7" grinder showing what a good rest for chisels would be.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390491&thumb=1
Magnifying glass mounted on the eye shield to better see the work area when a NortonA60OBNA2 toolroom cut-off wheel is being used.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390489&thumb=1
Making your own brad point bit from metal working drill bits.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390493&thumb=1
Another shot of the A60OBNA2 wheel grinding brad point bits
https://www.woodworkingtalk.com/attachment.php?attachmentid=390497&thumb=1
Tricked out Baldor 612. Its such a good little 6" grinder that it is worthy of this extra effort.
https://www.woodworkingtalk.com/attachment.php?attachmentid=390495&thumb=1
The back of the grinder enclosure showing a receptacle for a work light.
#24 ·
Here is an old trick that works fine. Leave the motor at 3600 rpms. Turn the grinder on and let it come up to full speed.
Now turn the grinder off and start grinding your tool. When the wheel stops, look at the grind, you may be surprised.
If the grind needs more work, repeat the process.
About 50 years ago I stumbled on to this trick when the electric went off during a storm. I was grinding a roughing gouge and always had problems grinding a single facet. Mostly hit and miss back then. When the electric came back on I looked at the gouge and the grind was perfect. I thought it was dumb luck but decided to try grinding other lathe tools.
Every tool I ground came out either perfect or nearly so. Then tried plane irons and chisels. Spent several hours sharpening every tool that needed it. I can't explain why, maybe because the grind is better controlled.
It works, that's what is important.
mike
#26 ·
Bob, I tried a magnet on the wheel guards and they are definitely magnetic, as are the other painted parts. I know heat-treating has come a long way and the aluminum tables on my little suitcase planer and Toshiba miter saw seem reasonably stout, you just can't been cast iron for vibration dampening.
Bill
#27 ·
As I said, your grinder is cast iron and a good quality USA-made cast iron to boot, not Asian peanut butter iron.
A lot of the cheapie grinders these days have stamped steel inside and outside guards that seem to be rejects from a low-end frying pan factory.
You've got an industrial quality grinder that will never be made again.
