Since i'm as big a nooby as you'll see around here I"m just trying to clear something up. Doing my first mini project, just refinishing some ikea chairs i picked up on the cheap to finish my living room redecorating and I just want to make sure this is ok while I can still return some stuff to Ace Hardware. I"m using General Finishes Java gel stain to refinish them if i ever in my life time finish the sanding which takes way longer than i thought it would. I picked up from ace hardware some spray indoor polyurethane semi gloss and I just want to make sure this is ok. It's a urethane based stain, no clue if that's an issue for a polyurethane based clear coat.
They of course recommend only their products for clear coating and recommendations from others are all over the map. Will this be ok?
Also I want to get recommendations about final finishing. I'd love for these to be really smooth, i can't sand finer than 150 before applying the stain, after a couple coats of clear coat should i lightly sand with a really fine grit just to get it really smooth?
Thanks for the help in advance!
