Oscillating Tool blade recommendations?
1 reading
6.2K views 14 replies 8 participants last post by  Tatorman
HI Folks,
I build doghouses for Habitat for Hounds and I use an oscillating tool for trimming things up. I am having trouble finding oscillating tool blades that last very long. I have been using Dremel carbide blades because I occasionally need to cut off a 16 gauge nail that has gone awry. The blades are suppose to be for metal, but I find they do not last very long. I am considering buying a second oscillating tool just for metal and use my existing for wood only. Can anyone recommend a blade that lasts longer than the Dremel?
Thanks,
Erv
I could only find one oscillating tool blade manufacturer who makes there products in the USA. I noticed that they were in all of the high end lumber yards that I visit, and were not found in either the orange or blue big box home improvement stores. So on my next visit to a high end lumber yard, I looked into the prices, and found out why these blades aren't sold at big box stores. So I bought a couple. Not a trivial expense, at $30 per blade. But after a year of usage, cutting embedded 16d nails out of buildings, I still haven't unwrapped the second blade.
Here is the About page of the blade manufacturer (Imperial):
The specific blade I use is on the front cover of Imperial's 2016 catalog shown below. It is the carbide "MetalHead" blade, that is now called the "Storm CarbideExtreme", I think due to some other company trademarking the name "Metalhead" and suing Imperial up the wazoo for infringement. Nevertheless, the key thing to remember is the blade number, which is model "360", because Imperial uses the word "Storm" and the gold colored tooth tip to denote other model blades, like the 330, the 340, etc, which are titanium impregnated at the tips, but are not carbide like the 360 is.
Below is the front cover of the 2016 catalog. The 2017 catalog will show the same 360 series blade with a gold tip and the words "Storm CarbideExtreme" instead of "MetalHead". It is Imperial's "halo" top tier blade. Why mess around?
Wood, steel, masonry, plastic, and flesh rated.
You are most welcome Tatorman. Glad to have helped someone on this forum. Lord only knows how much help I need, and will need, in the months and years to come.
One alternative that some could consider is one model of Bosch blade with carbide that is made in Switzerland. Not as long as the Imperial 360T, which is why I prefer the Imperial. The Bosch also isn't as thick or as wide. But for anyone reading, it may be of interest to know that Bosch does sell a carbide tipped OMT blade, because Bosch OMT tools, and some of the newest Fein OMT tools, have a special blade mount that I believe the Imperial will fit, but am not sure, so know at least that there is an alternative carbide blade for those special new OMT blade mount patterns (the names of which I sadly forget, because none of the three OMT tools that I own have those newer blade mounts, whatever they are called).
#14 ·
If you are using metal cutting blades to cut wood, you are behind the power curve to start. A metal cutting blade will cut wood, but very slowly as the teeth are entirely wrong.
Use a wood cutting blade in your tool until you need to cut a nail and then change. Any brand wood cutting blade is going to be better than any brand metal cutting blade.
Thanks GeogeC for the advise but, I would be constantly changing blades. Mostly I am cutting 16 gauge pneumatically driven nails that have been diverted due to the gran of the wood. I only cut wood to cut the opening on a Habitat for Hounds doghouse entrance (https://www.gofundme.com/ed5oxo) (
) and when the sheet material (plywood ) slightly overhangs the framing.
