I've had the sander, (DWE6423), for a number of years without any problems. On my last project the pad came off. It actually tore off the body by tearing through the holes where the mounting screws are.
I have obviously used it for sanding, but I have also used it with 3M white non-abrasive pads when applying Osmo. I did discover the hard way that the 3M pads clog the Velcro hooks and eventually won't allow sandpaper to stick. So I bought a second Velcro pad for sandpaper and have been using the original pad with the 3M pads, (I do have to clean off the sander pad occasionally so that the 3M pads will stick).
I see two possible causes for the sander pad tearing loose:
I didn't get the screws that attach the pad to the sander tight enough even though I carefully tightened them until they wouldn't tighten any more.
Using the 3M pads to smooth the Osmo caused too much torque and that ripped the pad off the sander. But it seems to me that the 3M pad would "misbehave" first...
Any suggestions or info would be appreciated.
