My miter saw (model 3802) is just a wee bit off from a perfect 90 degree cut. I'm about to make about 40 cabinet doors, and they'll be a lot easier to assemble if the cuts are right. The manual says to loosen 4 screws that connect the fence to the base. Next, it says to correct the setting indicator, so it shows '0' when you're cutting at that angle.
Trouble is, the picture doesn't point to any screws (!). There are 6 bolts connecting the fence to the base (from the top), and 5 nuts connecting the round miter track to the base (from the bottom). The bottom also has 4 screws that only seem to connect the feet to the base (?)
Am I supposed to simply adjust the fence (from the top)? That seems easy, but doesn't involve the miter or its indicator. I didn't want to loosen anything until I understand what I'm doing.
