Fence and fence running bars needed
226 views 15 replies 6 participants last post by  Steve Neul
I have this table saw and i need a fence
#11 ·
A see 2 bolts on either end of the fence both are tightened to their max. I really don't see any adjustment for the main lock but the far lock has its adjustment bolts bit the lever that locks it does stay down it springs up immediately. The main lock stays locked but barely. When. I took off the fence I saw a semi circle thick metal that pushes against the rail with alot of wear and they don't make them any more
#14 ·
I suggested a shim to increase the pressure of the cam against the shoe.
Will that work? It should only take a piece of spring steel from a shipping strap cut to size and bent to a curve.
Try it and let us know.
You won't find repair parts, only a used fence head or an entire fence.
