I need to hand hold drill a clean straight hole and plug it with a dowel.
A forstner bit works great but .......
only if I can use it in a drill press, which I can't.
Note: this is just an example work piece to help the pic out.
I have a pilot hole drilled, see position #1,
then I screw it using a wooded washer #2
and the 1/2" birch ply panel gets glued down.
#3 is a forstner bit used in a drill press,
notice the oh so clean hole.
this is even with the pilot hole ....
but with the pilot hole the center of the forstner bit
has no place to center on so it walks around marking up the panel.
#4 is my hole plugged with the 5/16" dowel which is 1" long.
#5 is using the drill bit shown ...... it is dull ....
and you can see the ragged hole edge it leaves.
What kind of 5/16" bit can cut a clean hole
with the prior pilot hole already there?
Dowels, I need to cut them.
I thought about cutting them as I install them.
I have a flushcut saw and the multi tool ......
they both leave marks .....
so I want to pre cut plugs and push them in but
I get ragged edges and then have to sand them down.
Notice I used the table saw to cut these examples.
How can I cut them cleanly?
This is for both cosmetic and strength of the joint btw,
even though the panel is already glued down.
Drilling Jig.
I don't want to hand hold drilling these holes,
I can't keep it straight!
So I thought about what jig or stand could help?
I'm doing this on a flat panel
so all the pics I see of doweling jigs don't show that.
I thought about a mini drill press but can't find one.
Lee Valley has all kinds of jigs .....
Dowelmax, Kreg, the "Versatile Drill Guide" (which I'm leaning toward right now)
Rockler has their version too.
I have one of those drill stands but it doesn't work all that good.
Drilling Jig.
