61 - 80 of 95 Posts
#44 or #51? They are not the same. My position is #44 is wrong so why was it included in this discussion? #51 is same as OP switch and agrees with my posting #7 at the very early part of this discussion
where are you getting you wiring information from?
You haven’t answered my questions. Which photo do you want to go with?
To sit there and say I’m wrong is not good enough. Do you know the difference between A and B contacts? Do you understand the theory of remote start/stop motor control?
I don’t need to understand anything I have a working switch in front of me. Mine works and your doesn’t …simple,.
I have the correct wiring.,No clue to your information..
yeah, this is why i hate electrical question on this forum. unless you know what your talking about on control wiring, you shouldn't be in this thread. i believe weepee has enough experience to wire the switch with all of the wires off the original switch just by using the wiring diagram.
I have the same saw as the OP.. A 34-802. it doesn’t get any better than that..
If you want to manipulate the switch, by all means do it incorrectly.
I stayed out till ai realized I had the exact same saw..
My switch is wired the way Delta wired it.
correctly wire for a 34-802 Unisaw
If the OP’s switch is broken and trying to bypass, I can’t help with that..
I don’t need to discuss this with you . Your not the OP.
Please stop…….
I think if you looked carefully and knew anything about this topic you would realize that both your switch and his are WIRED EXACTLY THE SAME.
LOL
Thank you. Time to end this discussion. The most of it is no help to the OP
I found a discussion on the Delta Unisaw contactor wiring issue here, with wiring diagrams:
If I have time today , I’ll take a picture of the main box on front on of the 34-802. It will show how it is correctly wired in a working 34-802…
While waiting for a picture of your control panel I reviewed the thread back to these posts #66 and #67.
Lo and behold! I skimmed the message too quickly the first time. Both saws are wired exactly the same!! You will notice the red and white are on the NO terminals and the black and white are on the NC terminals with a jumper between the two. All of this agrees with the wiring diagram in posting #1. No surprise to me because one way or another electrically they must be the same.
End result the OP needs to move the red wire to the unused NO terminal. Funny thing I pointed that out very early in this thread.
No need to provide the group with a photo of your control box.
61 - 80 of 95 Posts
