Clear spray paint over stained wood?
82K views 18 replies 4 participants last post by  HowardAcheson
Can you spray clear spray paint over stained wood?
Yes, you can spray the rustoleum clear on a piece of furniture. Be sure that the previous coat is fully cured and be sure to sand with 320 or 240 grit before applying your clear. Most of the spray paints are vinyl base, which will move some what with the wood and will not cold check on you.
Where did the polyurethane come into the picture? From what I've read so far, you are using an oil based stain and a "rattle can" clear finish. Is the clear finish a spray polyurethane or some other type of finish.
I suggest strongly that you prepare a test board. Apply each of your proposed finishes to it and then apply your clear coat. See if the different finishes play nicely together. Many "rattle can" finishes contain solvents and thinners that can damage prior finishes.
He stated that he would rather use a spray can clear rather than use a brush on poly over a stain...........
If this is the case, then he can use the rustoleum clear over the stain, whether its an oil or a dye stain, as long as the stain is completely dry before he sprays on the clear. Most enamel and vinyl based "spray bomb" clears contain ketones, tolulene, and xylene, depending on the formulation makeup......all of which are sometimes found in most industrial clear coatings and will not impact the stain.
However, it is always best to do a test sample before applying to the project when in doubt as you suggested.
Now do I think it will be easy to use a spray bomb rattle can clear rather than using a furniture related rattle can clear? NO. I know most non furniture related spray bomb clears are meant for a final coating over a prepared flat surface (painted) and do not contain sanding agents needed to produce a slick finish over wood.
#13 ·
If you insist on rattle spray cans, either Deft or Mohawk sealers work great followed by the same brand of topcoat in a spray can of whatever gloss you would like......they contain ALOT more sanding agents and are made more for wood applications.
It would still take 3-4 coats of sealer and maybe 2 coats of a topcoat to really get a good finish with the cans due to the fact thats it harder to spray 3-4 wet mils out of a can versus with a spray gun, and they do not contain as many solids.
#14 ·
I don't see anything wrong with using the Rustoleum as long as it's not mixed with other products. I would avoid using spars unless the project is being used outdoors. A spar is a little softer than interior finishes so it can expand and contract with the temperature extreams of being in the cold and hot sun.
If the project is large you might have difficulty spraying it with any rattle can finish. They put out so little volume it's hard to keep a wet edge in order to have a uniform sheen. In other words on large areas it will end up having streaks in the finish. A cheap harbor freight sprayer will do a pretty good job and it doesn't take an expensive air compressor to operate it. I could spray something the size of a chair with a little smudgepot compressor.
Thanks for the info guys
I started a spray thread based around compressor spraying a while ago. Leanred a lot and found out it might be better to go the can route because the Preval sprayers are junk.
Can you post a link to the "cheap HF sprayer"? Is it an all in one unit or are you referring to a pancake compressor and gun
#18 ·
Yes, There is enough air in a pancake compressor to spray a small project like that. The problem you would run into with a larger project is the compressor would run out of air and you would have to stop and wait for it to catch up but the demand on a small project isn't that much. Of course if you can afford a bigger compressor so much the better. Then that is something you could upgrade later.
