Hello,
This isn't exactly a wood finishing question, but it involves the finish so I thought I would post it here. Feel free to move this if there is a better place.
At any rate, I need to glue some small applique decorations to an oil-based enamel semi-gloss surface and I am wondering what glue to use. These are small wooden and cardboard figures that have been painted and clear coated with gloss acrylic. One issue is that because of the irregular shapes, I don't see how I can sand the gloss off of the surface before application. I would like a glue that will adhere very well and it would also be nice if it didn't take overnight to reach full strength though that isn't a deal breaker.
A few of the figures are a bit warped. They are reasonably flexible and will press flat, but it would help if the glue was strong enough to hold these warped pieces flat after it has set up (I will clamp until it does).
Of course it would be a problem if the glue caused the paint to lift. The last coats of paint on this are spray oil-based enamel. How long should I let that dry before I try to glue to it?
Thanks again for the advice,
LMHmedchem
LMHmedchem
