1 - 11 of 11 Posts
What wood are you using for your drawers? The local lumberyard wants $100 for a half-inch sheet of cabinet grade plywood. Yet the three-quarter inch plywood is about $60
Nothing wrong with ¾" plywood, if it's less than ½". See if you can find ½" Virola plywood. It should be fairly inexpensive. It should be available in ¼" also.
Work shop drawers? If I want to make drawers for the shop I can usually find something lying around that will work. I certainly would not spend $100, or even $50 for that purpose. Would not matter if it was plywood or solid wood.
Master firewood maker
For mine, I used 1/2" B/C ply and 1/4" lauan for the bottoms. I used rabbit/dado joinery. They ain't pretty, but they are very solid.
I grabbed a couple of pics of the drawers under my workbench. White pine and plywood make up the main drawers. The drawer on wheels under the workbench is made up of whatever I could find in the shop. Some of it is 1/2 inch and some is 3/4 inch.
For the main drawers, I used simple rabbited joints with false fronts. The should last a long time.
Last summer when I started my garage makeover, I dismantled my old workbench of 25+ years. The drawers were 3/4 inch plywood boxes with simple butt joints that were glued and nailed with finishing nails. I had to beat them apart with a 4# sledge hammer. And they had been holding a lot of heavy stuff for all of those many years. I have since reused most of the wood for other projects.
Good luck.
Mike
1 - 11 of 11 Posts
