Water Cooled Sharpeners
Hack,
I have both a Delta and a Maketa water cooled sharpener. Both are on the shelf collecting dust.
After using them several times I determined that I could use good quality bench stones faster then I could put water in the Delta or Maketa prior to use and drain the water and clean up after use. Their stones must never sit in the water as they are soft to start with and sitting in water makes the submirged side even softer.
These soft stones also develop groves with moderate pressure. If you sharped a 1/2" chisle it's easy to develop a 1/2" grove----same is true with sharpening a turning gouge. The use of various jigs or fixtures help but do not eliminate the weakness of very soft stones.
I'd love to find someway to get rid of mine as they were not the "Silver Bullet" I had expected. Spend $100 and buy 8" course, 8" medium and 8" extra fine high quality bench stones and then invest a few hours mastering their use.
Best Regards,
Woodchips
