I plan on building a couple of block planes, jointer plane, and then some specialty planes. I've seen plenty of different designs. I'm curious though about the wedge design. There are some out there that make the simple to build cross pin and wedge design like the Krenov, but I'm a bit worried that the pin might leave something to be desired because wood shavings could get trapped under it (no personal experience, just a thought). It seems someone else thought about that too, because I've seen designs that have a rebated cheek cut into each side of the plane that the wedge fits into. This seems like a clean design. So, now we go high tech... Like this one http://www.inthewoodshop.com/ShopMadeTools/CoopersJointer.html I've seen a design for making a metal cap lever that is pinned or screwed into the side of the plane and uses a thumb screw to apply the wedging action. Obviously this would be the hardest to make.
I'd live to hear your experiences or advice about the different designs of holding securing the blade into your plane. What would you make different if you did it again?
