1 - 6 of 6 Posts
I want to make some window cornices and have a few questions. I could just wing this and they'd probably come out okay, but I want them to come out better than okay. This is for 3 windows on a bay with the smallest dimension from the window to a corner of roughly 6". So what I'm thinking is getting some large crown moulding and make the lower angle about 1" larger on either side of the window. I will of course have to be careful on how large of crown mould I use as to not go over my 6" maximum. Then basically put a piece of 1x over the top and let hang over about 1/2" (still not going over my 6" max). Once that is all figured, I will need to mortise out half the dimension of the back side to fit in a 1/4 ply backer. Then a couple of keyholes for mounting. Does that sound like I'm on the right track or not? I've seen these a million times, but you know how it is when you go to start cutting up lumber! Any advise will definately be appreciated.
RealMacgyver,
This is a trim job that I did last year, Look the the sides of the mantle at the windows, is this what you are looking to do? I basically cut down a stock widow stool and crowned it making sure to wrap the crown around the edge. I nailed it to the window framing and then attached a trim piece to the freize board to conceal my nails. Trim the rest of the window with stock casing.
Hope this helps,
Scott Mordecki/ Nailgunner7
Are you talking about making a continuous sill that runs along the bottom of the window's with crown underneath or something entirely different just not sure if I'm understanding what you are trying to achieve.
Nailgunner, that looks real nice.
crazyjohnni (and anyone else): I guess I could permanently attach something, but I had a hanging style in mind. The ones I've seen similar are usually sold as shelves and use a keyhole slot on the backside for mounting, this way you never see the hanger. I guess the main reason I want to do it this way is because they will be a gift. I want to finish them and then I can mount them in a few minutes. They will go above the window on the inside. They will be a shelf also, but not very deep. Hope that makes a little more sense. Maybe what I'm talking about isn't called a cornice? Sometimes we have to make up our own names for things, ya know what I mean.:laughing:
1 - 6 of 6 Posts
