1 - 15 of 15 Posts
So I'm looking to buy my first set of dado blades for my Ridgid 4510. I'm just a weekend woodworker and have no idea if I should get a 6-in or 8-in set. I really don't see myself ever making dados deeper that an inch, so wouldn't the 6-inch set be a better idea? I thought I'd come here first before dropping any coin as I really don't know anything about dado sets and dimensions.
Thanks in advance
go with the 6"
from here: http://www.ebay.com/itm/6-CARBIDE-T...927?pt=LH_DefaultDomain_0&hash=item41718f8f17
I'm not familar with this brand, but it has C4 carbide and the price is very reasonable.
If you like the bidding war process, this is a great set if you win a low bid:
http://www.ebay.com/itm/Systi-matic...778?pt=LH_DefaultDomain_0&hash=item25825b6572
A tip on winning, wait until there is 2 minutes left. Raise your bid to $50.00 above the last price. The system will automatically bump your bid up $5 or so, not the entire $50.00 amount, and by the time your competitors bump their bids you will have won, and they won't have any time left. DAMHIKT :yes:
from here: http://www.ebay.com/itm/6-CARBIDE-TIPPED-30-TOOTH-STACKED-DADO-GROOVE-CUTTER-SAW-STACK-BLADE-TOOL-SET-/281078107927?pt=LH_DefaultDomain_0&hash=item41718f8f17
http://www.ebay.com/itm/Systi-matic-Dado-Blade-Set-Brand-New-Never-Used-/161100817778?pt=LH_DefaultDomain_0&hash=item25825b6572
Really...bid $50 over. Sounds like a scam to me. No thanks
Sawdust Creator
Keep in mind the tooth on an 8 inch dado will be traveling faster, and in my experience produce a cleaner cut in softer woods....however a 6 inch will cut through harder woods easier as the tooth will have more force behind it...
Check your owners manual. They only recommend a 6" stacked dado for that saw and you can't cut beveled dadoes. It's the weight of the set that is an issue with a smaller saw like the Ridgid, too much strain on the arbor and motor. Probably not much to worry about with occasional use but could be if running larger dadoes blades all day. There can be interference issues with the full width of a stacked 8" set, too. It's true that most dadoes you cut are not very deep but sleds might be used that raise the stock and the dado cut can be deeper with cuts like tenons. However, there are other ways to do dadoes besides using a stacked dado on the table saw and in many cases, those are a better choice.
SS user
As Joe B points out, an 8" will do 1/2 depth cuts in 4" stock. However, I'd heed Hammer1's caution.
Often, a router will suffice for most dado work
I have an 8" and wish I'd have gone with a 6", though the 8" has a better cut that my old 6" did. Most of my dado use is for box joints.
It is a valid bidding strategy...but your hoping no one else tried it either.
I have done the same thing in the past. I would wait as long as I could stand it, then enter my maximum bid that I would pay. ebay does the bidding for you until it reaches your limit. Then you are out if someone else comes along.
There is also software that will do the same thing only it will wait until the last second! :eek: I think that is called "snipeing".
John
The other problem with the 4510 is the riving knife retaining hardware will likely get in the way of the 8" set if you have much of a stack on it. I just run the Freud 6" stack and the only time I didn't have enough depth was cross lapping some 2x4's. I took the last 1/4" out with a router and template bit. :smile:
According to the manual, max dado is 6" diameter, 3/4" stack, I don't recall seeing anything about beveled dado's, will have to look that up.
1 - 15 of 15 Posts
