Stains and Fillers
In today’s ever changing world, more and more products are available due to market forces and general reformulation. Therefore, we are not aware of every type of colorization and filling process available.
STAINS
Generally speaking,
Waterlox Original Sealer/Finish can be used over any type of stain (water-based, solvent-based, alcohol based dyes, fast set types, etc.) provided it is completely dry (follow manufacturer’s recommendations for dry time or wait 72 hours, whichever is longer) and does not contain any waxes or silicones. We also recommend that you steer away from any type of stain that forms a film over the wood, for example a stain containing urethane or some thicker gel type stains.
TIPS
- If staining a wood project, do not skip any of the recommended coats of Waterlox as described in the project guides.
- An unstained surface finished with Waterlox Original Tung oil finishes produces an old-fashioned, hand-rubbed natural looking finish. Our special formula based in Tung oil brings out the natural patina of wood. With some species of wood this will dramatically change the look and staining may not be necessary, we suggest testing an inconspicuous area of your project or a scrap piece of wood from your project first before assuming you will need a stain coat. Regardless if stain is used or not, you will want to test all coats of the finishing system before making your decision.
- Keep in mind that not all pieces or boards of a single species of wood will stain the same; some will not match your sample board. Your stain/topcoat system may not transfer from one species of wood to another with the same effect.
- If stain is desired, be sure to follow the manufacturer's directions for cure time or wait 72 hours, whichever is longer, before applying coats of Waterlox Original Tung oil finishes. NEVER apply Waterlox Original Sealer/Finish over a stain coat that is not dry. Applying finish over top of it will only elongate the dry time because oxygen will not be able to get to the stain coat.
- NEVER sand a surface that has been stained as this process will change the color.
FILLERS
Most fillers are compatible with Waterlox Original Tung oil finishes other than those containing any wax or silicone. We also recommend using fillers that are marketed as being paintable and stainable, as this is an indication that they can be coated.
Previously Finished Wood Application
Surface preparation is one of the most important steps when refinishing wood. Waterlox Original Tung oil finishes perform best over bare wood and are not designed to be used as a top coat over previously finished surfaces (does not refer to stain coat(s) if used). Strip previously finished surfaces to bare wood, and then apply as described under “New Wood Application”.
If stripping a previous coating off the surface, doing a “sand and recoat” (and it is not previously a Waterlox product) or where not possible to apply to bare wood, our Waterlox Original Sealer/Finish can be used as a primer/tie-coat. It is imperative to identify the previous coating on the surface to know how to proceed.
Waxed surface. Nothing will adhere to wax other than more wax, and wax surfaces are extremely difficult to re-coat. In this case, you will need to strip the surface completely of any wax. We recommend against sanding or abrading the wax from the surface first as this has the potential to spread the wax around even more and not remove it completely.
We recommend stripping the wax from the surface by using water and ammonia, following the directions on the manufacturer’s label for “stripping wax”. If there is a wax build up, the wax may become gummy and need to be removed by scraping or wiping with rags. Repeat the procedure several times to be sure all wax has been removed. To remove any wax that has penetrated the wood fibers, the surface should be sanded to bare wood.
TIP
- Even though the wax has been removed from the surface, it may still be present in any gaps or spaces between the boards. These are extremely challenging to remedy and may require scraping to remove the wax. If Waterlox or any other coating is applied over these gaps/spaces and the wax is still present, the coating will not dry and will remain soft and cloudy.
- As we mentioned in the beginning of this section, removing wax can be very difficult and great care needs to be taken in doing so thoroughly. In some extreme cases, the wax may not be completely removable and the surface may therefore not be re-coatable.
After the surface has been stripped completely, begin by coating a 2’ x 2’ test area and allow it to dry for 24 – 48 hours. Initially, test for adhesion with your fingernail. It should be difficult to remove the coating if the wax has been properly removed. Also observe the coating that bridges the gaps/spaces between the boards. The film should not be cloudy or soft. Next, we recommend conducting a cross-hatch test to check for adhesion before beginning the entire project.
Surface coating finish (e.g.: oil-modified urethane, water base urethane, etc.). Since a surface finish lies on top of the wood, and will block the penetrating ability of Waterlox Original Tung oil finishes, we recommend sanding down to bare wood before applying Waterlox Original Tung oil finishes. One method of testing for an oil-modified urethane coating is to apply a drop of ammonia to a small, inconspicuous area. Cover the drop with something hollow to prevent the evaporation of the ammonia (e.g.: Dixie® cup, shot glass, etc.) If the film where the ammonia was applied becomes yellow, it is most likely surface finish.
When removing the previous surface finish, the last sand should be done with 100 - 150 grit sandpaper.
Other Oil Coatings (e.g.: raw non film-forming linseed oil, soya oil, Tung oil, mineral oil, etc.). Our Waterlox Original Tung Oil products are most likely compatible with these types of finishes. One method of testing for an oil coating is to apply a drop of ammonia to a small, inconspicuous area. Cover the drop with something hollow to prevent the evaporation of the ammonia (e.g.: Dixie® cup, shot glass, etc.) The ammonia will not only yellow the film, but will eventually wrinkle the film if it is an oil coating.
To prepare the surface, we recommend cleaning the surface with TSP (trisodium phosphate) and water, doing a clear water rinse and allowing it to dry for 24 hours. After the surface is dry, a light buff with 0000 steel wool or 320 sandpaper is sufficient. After the surface is prepared, re-coat with the Waterlox Original Tung oil finishing system.
To be sure the surface is ready, we recommend conducting a cross-hatch test to check for adhesion before beginning the entire project.
Shellac. Our Waterlox Original Sealer/Finish is compatible with dewaxed shellac. One method of testing for shellac is to apply a drop of alcohol to a small, inconspicuous area. Cover the drop with something hollow to prevent the evaporation of the alcohol (e.g.: Dixie® cup, shot glass, etc.). The drop of alcohol will dissolve the shellac if the finish is shellac.
To prepare the surface, we recommend cleaning the surface with TSP (trisodium phosphate) and water, doing a clear water rinse and allowing it to dry for 24 hours. After the surface is dry, a light buff with 0000 steel wool or 320 grit sandpaper is sufficient. After the surface is prepared, re-coat with the Waterlox Original Tung oil finishing system.
TIP
A cross-hatch test is an industry test for adhesion. Waterlox Original Tung oil finishes are penetrating oil finishes and are therefore best used on bare wood (does not refer to stain coat(s) if used). Sometimes, sanding the surface is not an option for a project. To test the adhesion properties of a combination of finishes, test on an inconspicuous area first.
Directions to test for adhesion: Scuff sand a small inconspicuous area with 320 grit sandpaper. If you will not be sanding the surface to bare wood in the actual project, clean the area with TSP (trisodium phosphate) and water and complete a clear water rinse. Apply 1 coat of Waterlox Original Sealer/Finish. Allow the finish to cure for 4 days. Scratch a “tic-tac-toe” board into the cured finish by cutting through the film and into the wood. Place a piece of Scotch® tape over the cross-hatch and press it down firmly with your finger(s). Pull one end of the tape off with a steady motion. If there is any film on the tape, other than the pattern of cuts you made into the substrate, this finish combination will not have adequate adhesion.
If the test fails, proper sanding of the surface down to bare wood, or chemical stripping of the previous finish will need to be performed before applying Waterlox Original Tung oil finishes.
