1 - 3 of 3 Posts
On part of a frame I'm making with some 180yr old heart pine the waterlox finish seemed to darken to a greyish finish one part of the sap wood. There was alread a black spot in that area you can kind of see in the picture so I'm not sure if my attempt to sand that out ended up spreading it out more in that area and I just couldn't see but it ended up reacting with the finish. Question is, is there anything I can do to take that dark coloration out? I've just put the one coat of finish on.
The waterlox didn't do it. The color is a mineral streak in the wood and the finish just exposed it. It would have done the same thing if you had put water on it. The only solution would be to strip the finish off that piece and bleach the spot.
Interesting. Thanks steve! What's the best way to strip off the finish? I'm guessing not just sanding it. How does bleaching affect wood? Does it not take away the woods notural coloring and make it have a much lighting spot where the bleach hit?
1 - 3 of 3 Posts
