I have been using Minwax Hand Rubbed Poly Satin finish to finish maple and walnut picture frames and I really like the ease of application and the look of this finish. The satin finish looks very natural and since it is an oil-modified finish it imparts a subtle amber tone to the wood.
I also really like the ease of application as I can simply rub it on with a cloth, let it dry for 10 minutes and then apply a second and final coat (sometimes I will do 3 or 4 if I want it to appear less satin).
What I don't like are the fumes and the environmental impact. Is there a water-based finish out there that will give me the same or very similar look to the wipe-on poly? Is there one that is similarly easy to apply?
In case you are not familiar with this exact product, basically what I'm going for is the satin look of tung oil, boiled linseed oil or any other oil really but from a water-based finish. I have also heard it is similar to General Finishes Arm-R-Seal satin.
You could always start by rubbing in a light coat of linseed oil, then finishing with whatever water based finish you want. Best of both worlds that way. I do it all the time with shellac, which yes, I know isn't water based, but same principal at work
Most of the water based finishes I've tried dry to quickly for wiping. General Finishes Woodturners finish seems to work a bit better; at least on the lathe, where in basically wiping it on except that the object is moving instead of the finishing pad. I use a small cosmetic sponge wrapped in a piece of panty hose. It seems to maintain a wet enough edge. Like all water based finishes, it does raise the grain on the first coat, but that's the nature of the beast. General Finishes Woodturners Finish also has an amber tone although it's not exactly like oil.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Woodworking Talk
A forum community dedicated to professional woodworkers and enthusiasts. Come join the discussion about shop safety, wood, carpentry, lumber, finishing, tools, machinery, woodworking related topics, styles, scales, reviews, accessories, classifieds, and more!
