Hi guys, new here and just posted an introduction. I am new to woodworking and have made a small sofa end table. I know its not great, i am just starting out. I shop for lumber at lowes and have a hard time finding good stock to pick from, and sometimes even when my cuts are accurate, i notice that the table top is not flush with one another. I know that the stock isnt uniform, i am just curious how i can make this more presentable and flat so that when i put things on it it doesnt look ghetto. I bought a Porter cable electric hand plane and took a pretty nasty gouge out of the wood at the end of the board on some scrap, is that the best way? or a good orbital sander and start with coarse sand paper and then finish? Any advice is appreciated. The plane is like 3 hours old so i can return it.
TexasAngler,
what tools and machinery do you have in your garage ?
These fellas have good advice ,
but to follow it you have to have all the gear and know how to use it .
When practising with the electric hand plane , start with the blade retracted , (front base lower that the back one ) and take gentle sweeps along the timber , lowering the blade a fraction each time until it makes contact with the timber
The game is to see if you can take the fluffiest stuff that you have ever seen coming the wood . When you can do that , lower the blade a fraction more and take off flakes . Lower it again for bigger shavings . Continue in that vein a number of sweeps each time .
When the shavings are getting to look like woodchips , wind the blade back in to shavings depth .
Get in a reasonable bit of practice , keep your weight on the front tote , try to avoid lines and ridges , use the Vee in the base plate to arris an edge , round off another edge , plane some endgrain to see why we don't do it all that often .
Have a good play , its the best way to learn
