I have an 8-year old Unisaw with a 3hp motor. I notice excessive vibration in the blade. The saw is on a slab, and level. I know the bearings are sealed for a lifetime. So--any suggestions on how to minimize this vibration?
Well, I may as well get this party started. The finger tight thing is, in general, probably not one of the better recommendations for Joe Public. It is also not the blade changing procedure by any saw manufacturer that I can find. Just a few offerings:Basically, you need to go through the saw. Just because bearings are sealed, doesn't mean they don't go bad, only that you can't grease them. They usually last a long time and I wouldn't suspect them as the cause. Very often, it's a drive belt or pulley that is loose. The Unisaw should have three drive belts. Before doing anything, unplug the saw. Remove the blade. Check that it was free to fit against the arbor collar. You know that you only tighten blades finger tight, you don't use a wrench or you can bend the blade. The blade can get caught in the threads of the arbor or there can be some debris on the collar, either one, inner or outer. It may just be tension on the belt/s. Also check the alignment from pulley to pulley with a straight edge. A bolt or two may have loosened, allowing the motor to shift, releasing tension and going out of alignment. There is an allen head set screw in the grooves of the pulleys that often align with a key, a small rectangular piece of steel or a flat in the shaft. These can come loose. If the belts are off, you can turn the arbor by hand, like trying to break into a safe, to feel any roughness in the arbor bearings.
This is always a good time to go completely through the saw, checking every bolt. Don't over tighten any since tapped holes can easily strip. Open the electrical switch, clean all the dust out, under the saw, lube the lifting and tilt mechanisms, check blade alignment, set the fence, miter bar, reset the angle indicators, etc. Every saw should be gone through from time to time.
Glad you understand the problems with over tightening the blade. You cannot use two wrenches on cabinet saws, there are no flats for a second wrench. If you know about blade tightening, you may also know how to "tune" a table saw. We never know with most posters, some may have experience, others may not. You didn't give any pertinent info on your original post. Considering your question and what little you offered, it would be normal to assume you are a novice, most posters are. We all were at some point.
