I have a 5 gallon bucket beneath my table saw as im assuming is pretty standard. But for whatever doesnt fall down, I have a big window fan that I use. Its a 2350 cfm so moves a lot of air.When I cut,it generally clears the garage out in 7 or 8 seconds. As silly as it sounds, Ive gotten in the habit of holding my breath for a cut, then stepping back for a few seconds before continuing. But, I generally dont cut a whole lot at once. My current projects will require a bit more focus on the table saw so its time for a better solution.
I was going to do the cyclone collection but then I figured I have the big powerful fan, maybe harness that better.
The fan is 9 feet from my blade. As you can see in the pics below, I set up a real rough proof of concept. I framed the fan with some old Pergo, covered the face with cardboard, made 5" tubes from left over aluminum from when I sided thr house, and tie-wrapped and duct taped it all together.
I rested the end of the tube next to the saw and turned the fan on. It seemed to be a good high volume, low pressure suction, easily felt, and sucked a piece of cardboard up to it. When I drop sawdust near it, it sucks it all up.
But when I used the saw, I still had small particles floating in the air. Better than usual. BUT, even though there is less particles in the air, there is still some (a little more than I expected but maybe my expectations were too high) and now no fan to clear it out.
To be fair, this is a real rough test and there is plenty of leakage around the frame and cardboard and the window is only open 80% as its old and sticks. But to offset that, if I made this permanent, I would run it to along the rafter so it would be a longer run with three 90s.
I think 2350cfm is pretty good if I can harness it properly.
How much of the dust do you expect a collection system to get?
Is there a better place to put the hose? Front of the blade seemed better. I guess hanging from above, a few inches above and toward the front of the blade?
Any thoughts or expectations?
