I'm trying to speed up and/or make easier the process in which I finish multiple and similar projects. I have had success sanding to 220 and using Minwax indoor/outdoor Helmsman Spar Urethane diluted 50% with mineral spirits. I sand between each coat using 500 grit or steel wool. It takes me anywhere between 6-10 coats to achieve a glass like finish. 6-10 coats takes a lot of time. I purchased a spray can of the same finish. I am wondering if I can apply multiple coats of the spray and finally sand with steel wool before applying my diluted mix and achieve the same results?
Maybe there is a better way entirely that I can achieve a high gloss finish that is resistant to moisture and temperature changes. It currently takes several days or more to get my desired results. I am looking for a time saving/easier shortcut to get the same results. Any advise is welcome.
