Hello.
VERY amateur woodworker here. I normally don't have the patience for it.
I followed some directions on YouTube for making a guitar case. Basically, making a box, cutting it for the top/bottom and then covering it and putting on the hardware.
I went to Menards and bought their select pine - 1x6 to make the box. I wanted about 4" depth on the box so I couldn't use a 1x4 with it being only 3.5".
I used a Kreg jig and screws and glue to build the box.
I put some Home Depot 1/8" plywood on the top and bottom. I glued it and screwed the plywood on. I let it sit in the basement for a few days for the glue to dry.
I then removed the screws so I could use a roundover bit on a router on the edges.
Next, I cut the box on the table saw. I removed enough by where I cut to get the depth about 4.25" and a couple days after that, the top warped/twisted. It rocks when you press on two opposite corners. The bottom "seems" ok visually. The top is noticeably/visually warped.
Can this be fixed? How would I go about doing that? Or do I need to start over and do it differently?
The first picture is of the box before I cut it. The others are it's current state.
The appearance of the wood doesn't matter much since the entire outside will be covered in a vinyl fabric. I used wood filler and bondo to fill in the screw holes and other spots so the vinyl will be relatively smooth.
Thanks.
Thanks.
