1 - 3 of 3 Posts
Is it possible to cut crown molding along the long side of the attached window (crown goes to the ceiling), then miter another crown molding piece on the vertical side? Horizontal run would be a ledge. The rest of the wall would be recessed panel to make up for the crown molding. Much appreciated!
Crown molding is meant to go along the intersection of walls and ceilings. I don't get what you want to do when you say, "on the vertical side". You don't have an adjacent ceiling or wall on that side.
Also, it doesn't look like you have room for a very big crown above the window casing to the ceiling.
1 - 3 of 3 Posts
