I'm building a toy train showcase for my father in law. I guess they're not actually toys but they are electric train set engines put out to be collectables from a major rail company that has 20 different brands all under one main brand (21 in all, I guess they're the GM of the rail industry). He paid around $3000 for all 21 engines so I really hope this showcase STAYS on the wall.
My plan is to attach the back REALLY WELL as in a LOT of nails, and then screw through the plywood back into the wall, hitting studs in 4 places. Please tell me now if this isn't a good idea.
I made it to hold two engines per shelf, each sitting on a piece of HO track, and the main name engine will sit alone in the center on the top shelf. 11 shelves in all. The top shelf has boards slanting backwards toward the rear to create a centered position for the main name engine. I figure he might later have a brass plate made with whatever info pertaining to the engines on it and these boards will be a good place to display that. Since there was an odd amount of engines this was the only thing I could think of to keep the top shelf from looking like it had a bunch of wasted space. Cutting the back angle was fun. They were 69 degrees and the other end had 21 degree angles. My miter saw will not do a 69 degree angle. So I left it centered at 90 and put the 21 degree cut ends against the fence and gently dropped the blade into each board. It worked and I only had to make three to get two good ones. LOL
A large sheet of plexiglass will slide in from the right side between the face frame and the main carcass of the unit. I routed a slot in the bottom and top boards to serve as a track for this. The unit is made from poplar wood with two coats of early American Minwax stain on it to darken it up almost like walnut. Tomorrow it will get a coat of polyurethane. I still need to cut the lauan back and I will put maroon felt on that to make a nice backing visible behind the trains. Right now, it's fully assembled and stained.
This thing has several mistakes I made, being as I'm only a novice wood worker, but I think I covered them pretty well. For one thing, it was supposed to have a top piece of face frame to go with the side pieces but I forgot to allow for this when I cut the sides so I had to rethink my whole top piece to try to achieve the trim look I wanted. Originally the very top board was going to round over like it appears now, with cove trim below this. Instead I cut the cove into the top board and then made rounded over crown molding for the top. This retained the trim look I wanted and compensated for the mistake in my measuring. As a bonus, I think it looks better without the top face frame after all. So it was a happy mistake, but sure wasn't the only one. But overall, I'm satisfied with how it is turning out and I learned what NOT to do for next time.
I've learned a lot on this. It was my first experience with dadoes for shelving. My first project using poplar. My first display case also so I got to figure how to make the plexiglass install (still have to cut it to fit). My first experience gluing and clamping a face frame where I relied on the glue only to hold it, it worked and I actually got the edges lined up near flawlessly. Light sanding afterwards took care of a very slight inconsistency in the alignment. I've had a lot of firsts in this project. Next time I'll be more prepared.
Overall dimensions are about 32" wide x 48" tall so you get an idea of its size.
I'm absolutely loving the way the stain shows off white grain lines in this wood. Some of it was a little unpredictable. I think the board on the top shelf that's slanted came out a little dark. Also the bottom of the right face frame was dark also. I think maybe I over applied the stain on both areas, but otherwise I love the white lines showing in the wood. I'll definitely do this stain/wood combo again on other projects.
