I recently reshaped a bowl gouge (Henry Taylor Kryo) to a fingernail grind. I was trying to mimic a grind on another smaller bowl gouge (1/2 inch Thompson Tool). I think I came pretty close to the grind I wanted but here's the issue....
The tool now has a bit of a serrated edge that I can't seem to get rid of. Which in turn leaves little striations on the wood. What am I doing wrong? Is it difference in tools? (Thompson Tool doesn't have this issue)
Any suggestions would be appreciated.
Sorry, guys sometimes I don't think of those questions. I use the wolverine grind system. But I have the vari-grind 2 jig for the gouges. I'm a bit unsure if it's used the same as the vari-grind 1.
I did sharpen the tool again this morning. It has improved. I used a much lighter touch while sharpening. I will try to get pictures up later. Tips or suggestions?
I have an 80 grit wheel and a 120 grit (I believe) they are the wheels that come standard with Woodcrafts slow speed grinder.
Thank you for the link. I will watch them. I enjoy John Lucas' videos.
I need to get pictures up so I can show you more concerns. I will work on the tomorrow (@ work tonight). Thanks for the help.
