My wood shop has spent the last couple years being used as an auto shop. During that time I managed to acquire a bunch of new tools. So I went through and tried to clean up my shop and found I don't have storage for all my tools anymore. (I know, it's a horrible problem to have.) I've decided that a mechanics style tool chest would work well for me. I don't need a high security chest so I don't need to spend $800 - $1300 for a name brand steel chest. I am thinking that I can build what I need with inexpensive sheet goods and some drawer slides. This will be an 11 drawer unit with one full width drawer. The smaller drawers will be ~15" wide. (Yeah, I'll just slap this together quick.)
I have done smaller projects in the past but haven't built any cabinets or drawers before. I tend to over engineer things and don't have a problem with that persay, but I don't know how over the top I am going here. The case Will be approximately 3'6" x 3' x 1'2" and I am thinking 3/4" ply or mdf. The goal with the drawers is to get the same kind of depth as the commercial chests have so the drawers have to be higher to accommodate the thicker building materials. The actual height of the chest hasn't been determined yet because I haven't fully sketched it out yet. I will try to do that with Sketchup, but haven't had much luck with that in the past.
For the drawers, I am thinking about the same material as the casing for the sides and maybe 1/2" for the bottoms. I figure they would be better build with full dados as opposed to just rabbiting the frame to fit them in. Full dados would give greater strength but require greater drawer height. The overall height increase doesn't bother me, I can make that work. Is 1/2" overkill for drawers I am using 100 lbs slides on? I originally considered using 1/8" hardboard but I don't think that would hold up to that kind of weight over time. I also assume (dangerous, I know) that I want the drawer to be 1/2" or so shorter (height) than the opening they will be going into in order to allow for fitting. For the record, I haven't decided on drawer fronts yet. If I use 1/2" ply for the bottoms I will probably use that for the fronts as well.
The whole unit will be painted inside and out to help protect the wood from oils and grease.
Any additional thoughts would be appreciated.
