1 - 3 of 3 Posts
I am working with a birch plywood. I apply a dye stain over the entire board. Afterwards, I use a Frog tape on top of the stain to paint certain shapes. Once the painting is complete, I apply a water based Poly Acrylic top coat. The problem is sometimes the stain will either come up through the paint or will bleed over onto the paint, especially white. Can I use a sealer on top of the stain, but still be able to put Frog tape on top of, without messing the sealant or the stain up?
Super Moderator
welcome to the forum, Kevin.
what kind of paint are you putting on top of the stain ?
do you intend to put any kind of clear finish on top of the stain ??
Discussion Starter #3
This is a cornhole board project. I am using a standard Valspar Latex paint and I am spraying on a Minwax PolyAcrylic Top coat.
1 - 3 of 3 Posts
