1 - 3 of 3 Posts
Has anyone used this glue before... what's the procedure , No good ....any thoughts. I have used hide glue with good results but it's kind of a pain to boil up everything for a tiny project. Do you put it on both sides and apply the same as if hot hide glue.
If you have a small piece of veneer the titebond glue will work alright. On a larger sheet the glue tends to stay wet in the center for a long time. We did that one time on a 4'x8' and let the glue dry over a weekend and when we started cutting parts out of it found that about 10" around the parameter glued and the rest of it was still as wet as when if was first laid. Ever since then I've always used resin glue with veneer. It's a two part adhesive and once mixed it will harden regardless.
1 - 3 of 3 Posts
