OK............. I need to make a mold to vacuform some plastic..........
Each "leg" in the pic below is 3/32" long the the angles bieng 30deg to each other.......... anyone know of some kind of a bit that might work???? (It's a scale model of an ISO container........)
that's what I'm kinda trying to do......... Figure out how to mill the 30 deg angle...... that'as why I'm kinda thinking a v-grooving bit..... the finished size is about 3" long (for each strip) and 14" worth of this pattern...
Forgotten but not gone
Matt,
I don't know how money you have avaialbel for the project, but custom bits are no longer all that expensive. You could get a multi-stacker made to your exact specs. if there is even a modest amount of money behind the project.
And talking only 3/32 that "multi" could be many.
Actually, depending on the thickness of the plastic....... it will need to be smaller than that anyway.....
I may have to expriment and see what the vacuum draw is ... the
v-groove might work............
