Can You Use A Thin Kerf Blade On Regular Size Splitter? will there be a problem if the splitter on a table saw is somewhat thicker than the blade?
The blade appears to be about 1/16th inch thick and the splitter appears to be about 1/8th inch thick.
I inherited a cheapo home depot ryobi table saw from my uncle and since it probably needs a new blade, I was thinking of putting a freud diablo 40 tooth blade on it.
Since it is a thin kerf blade, will I need to change the splitter to a thinner one, too???
