Again it comes down to size. Friday I had to make some 1/16" x 5" veneer to repair an antique I was working on. I set up the table saw to 3/32" and resawed the 5" wide board cutting half way through and then turned it over and cut the other half. I made it slightly over sized so I could sand it to 1/32". Had I needed a wider piece like 7" it wouldn't have worked. I would have had to surface the wood down with a planer. When it would get to a 1/4" it would have to be applied to another board with two sided tape or spray adhesive to get it to 1/16" and then great care would have to be taken not to take too much wood off at once or the machine would tear it from the backer board.
