I've used it many times in the past with no problems, but this time it stayed sticky overnight and even out in bright sunlight this morning for a few hours .. So..I had to wipe it all off with lacquer thinner and even then a bit of it is still sticky..
I read an article saying it can go bad over time so that's what I have to assume is the case. I assume the cold weather this past winter did it.
I did get the majority cleaned up ok so I may go over some of the dry, dull areas with a quick wipe of BLO.. This was on dry eastern red cedar made into a planter .. I've made dozens of them using the same teak oil and it usually dries within an hour or so..
Ever experienced such a problem?
