1 - 20 of 20 Posts
I have a small shop, and have a mobile table saw. I got sick of all the small jigs, inserts, push sticks, blades, featherboards, pencils, tape measures, Wixey gauge, being in various places around the shop.
I was planning on just a drawer, but a drawer has to be below the rails. That means there's about 3" of unused vertical space, so I put a door on top over a tray. My inserts, pushsticks, extra tape measure, pencils, and Wixey gauge go in there.
Thanks for looking!
Discussion Starter · #6 · (Edited)
Hi everybody, thanks for the comments! I appreciate it!
Handy spot for those items - well done! Don't weigh it down too much, or at least check to make sure it doesn't throw your rails off.
David
Weight was definitely a concern, with that being the end furthest from the wheels.
I tried to minimize weight by using only 1/2" ply for the sides and the drawer, and only two little strips below the drawer. Even so, I can feel the weight bias when I move the saw around now.
It took a lot of fussing to get it just right, so I have consistent clearance as I slide the fence over it. It's been on there for about three months, and it doesn't seem to have drawn the rails down.
Termite
Nice job....I have to build one for mine to store saw blades in. Have a router in the way. Should be interesting...
Discussion Starter · #12 ·
Thanks everyone!
So this weekend, I had lots of blade and insert changes. That was so convenient having that top tray!
Senior Something
good idea. but if that finger hole is a through hole, then I'd worry about sawdust getting inside.
Nice idea. This is the first time in all my years I have seen someone make an extension that opened from the top. Good use of the otherwise wasted space.
Sent from my iPad using Tapatalk
You could make a simple adjustable leg using all-thread or a bolt threaded into a fold-down leg ... just enough to withstand gravity ... and gravity NEVER stops working.
1 - 20 of 20 Posts
