I recently picked up a used Powermatic 66 3HP in generally pretty good shape. Based on the S/N, I think it's roughly a 1987 vintage. Once I got it in the shop, I adjusted the table so the miter slots were parallel to the blade and then adjusted the rip fence to be parallel to the miter slots. It rips great and generally seems to be performing well.
However, I've just installed an aftermarket sliding crosscut table (Harvey Compass if curious) to the left wing and have been chasing my tail trying to get it to make a square crosscut on wider panels. I tried making all of the calibrations I could think of to the table itself and kept getting the same result. About a 32nd of runout over 12". I then turned my attention back to the saw itself, which I had assumed was true and square.
After double checking the blade for parallel to the table, it was indeed parallel to the miter slots, but only with the blade raised up all the way. If I lower the blade down to say 1" or so projection, I notice that the blade is no longer perfectly parallel to the table. It seems that when adjusting the blade height, the blade somehow swings slightly out of parallel. When measuring from the right miter slot to the blade, I'm getting a small gap (less than a 64th, but visible between my combo square ruler and the blade) on the back side of the blade(farthest from operator). The blade does stay vertically square as the blade is lowered though. I'm pretty sure this is the culprit for my non-square cross-cuts with the sliding table since I always had the blade lowered while cutting a 1/2" ply test piece. But I haven't been able to test it out yet by resetting the table with the blade lowered.
So my questions is what might cause the blade to go out of parallel with the table as the blade height is adjusted? Has anyone seen this before? Especially on older Powermatics?
