I have the Craftsman 15" drill press (model 137.229250). I have never used this feature before, but I recently wanted to turn the table 90 degrees to drill into the end of a board. The manual shows the bevel locking bolt and the bevel locking pin under the table. The manual says to "tighten the nut on the locking pin clockwise to release it from the table support". I used a socket wrench to tighten it several turns. When loosening the larger bevel locking bolt, the table becomes free enough to wiggle around, but it will still not rotate. I tried tightening the locking nut some more, but it seems to turn without moving. I kept tightening it for several minutes, but it never unlocked, and never seemed to move or get tighter or looser. It is too stiff to turn with my fingers, but easily turns when using a socket set with enough resistance to rachet on the back stroke. I tried pulling the locking bolt with pliers to see if it would disengage, but it did not help.
Can anyone explain how the locking bolt is supposed to work, and what to do if it seems to fail to disengage?
