That looks amazing. I honestly never thought about the continuity of the grain on the apron-drawer-apron but now I cant not notice it.
Hand plane.I dont understand. I make the cuts and the drawer front is 10x1.5
Glue it all back together with drawer in place, tight. Remove the drawer front and make the drawer.
At this point its a box with all side flush. So regarding the front, the left a d right side will have half blind DTs connecting it to the sides.
How do you then take off 3/32?
Im definitely not following.Hand plane.
So, cut the 3/32 off the left and right, but not the top, leaving the top to be planed at the end?Cut the 3/32 off of the drawer front first, and cut the drawer back to the same length as the front, then cut the dovetails. That’s for the side clearance. For the top and bottom edges of the drawer front, after the drawer is built use a plane to bevel the front edge slightly to create the gap.
Starting to sound complicated…So, cut the 3/32 off the left and right, but not the top, leaving the top to be planed at the end?
First question is, this is 3/32 off each side, right ? not 3/32 total (3/64) per side.
Also, if cutting the 3/32 makes sense for the sides, why not do the top the same way? What is the reasoning behind that process?
The fronts are the exact dimensions of the opening. You build the drawer off of the front, then plane the sides, top and bottom accordingly to give the gap. The 3/32 gap is all the way around. Tip: use a shoulder or rabbet plane on the bottom of the drawer front.So, cut the 3/32 off the left and right, but not the top, leaving the top to be planed at the end?
I only cut 3/32 off of one side. After glue up that allows for an additional 3/32 that can be planed off when fitting/adjusting in the opening. That is the total amount of leeway so that some can be taken off each side if needed to cleanup the dovetails.So, cut the 3/32 off the left and right, but not the top, leaving the top to be planed at the end?
I guess it just seems more intuitive to shave 3/32 off of each side of the front and then build the drawer. But the more I let it sink in, it makes more sense.The fronts are the exact dimensions of the opening. You build the drawer off of the front, then plane the sides, top and bottom accordingly to give the gap. The 3/32 gap is all the way around. Tip: use a shoulder or rabbet plane on the bottom of the drawer front.
If you cut the front with a gap to start & then build the drawer you’ll have trouble. This I know😉
Do you have a hand plane?
Oh yeah. Typo. I totally knew the difference between a dado and... a dado cut with the grain.Full height drawers are a bit tricky b/c you need internal support. The table below has a 3” apron and 2” drawer depth. Note the brace across the bottom.
For clarification I’m sure it was a typo 😁 — drawer bottoms go in grooves, not dados. Dados are cross grain grooves, rabbets are along an edge.
View attachment 449580 View attachment 449582
Im not sure what you mean. do you mean a veneer strip as the bottom of the drawer?You only need a 1/16 around the drawer.. on some I just put a 1/16 veneer strip for them to ride on. On others, I’ll put a dado in.the least challenging will be the veneer strip…
