Master firewood maker
Here is just one use i made tonight of the t-track on my bench: a guide for my circular saw.
You guys who have t-track in your benches ... how do you use it?
I have two tracks across the width og my bench and tracks around three sides of the top. I clamp everything. Don't use a vise...haven't needed one.
Great and flexible. Will hold anything I've tried.
Blue
Lots of uses. Clamping stuff together and hold it in place. Hold the piece while being cut or routed. Keep parts aligned when I do the assembly.
Note: The pic with the two routers - I attached a piece of scrap to the back side of the board on both ends so I could clamp it to the table. Then I ran the flush trim bit around the oval template to smooth out the rough cut. While still clamped, I removed the template and ran the second router around the inside with a 3/8 inch round-over bit. Switch to the next piece and repeat. Worked pretty good.
John
I haven't put one on my bench... yet, I can see some distinct advantages though.
I do know there are at least 3 distinct sizes (probably many more but ones that are generally available).
The ones Hartville tool sells match with 1/4" hardware, the ones Rockler sells typically takes 5/16" hardware and Peachtree pushes the 3/8" hardware compatible ones although they sell all three. For a workbench installation, I think I would opt for the largest, 3/8", version. I find the 1/4" ones more than sufficient for jigs though. :smile:
