Depends on what your definition of "basic electrical knowledge" is.I need more room in my breaker box in the shop to run my machines from. I am thinking a sub panel is the way to go.
Is a sub panel install something I can do myself with some basic electrical knowledge?
No, I would not do it myself without professional "help".I need more room in my breaker box in the shop to run my machines from. I am thinking a sub panel is the way to go.
Thanks for giving it to me straight. I usually end up getting myself into projects that are more complicated that I'm prepared for!No, I would not do it myself without professional "help".
There are ground bars, buss bars, neutral bars, load bars, aluminum or copper connections, anti-corriosion lubes, wire size factors, etc.... more than basic knowledge is required.
You may be better off to replace your existing shop panel with a large panel of the same rating with more slots to allow for more 220V breakers and such. These are decisions that would require an expert, a pro., a licensed electrican.
To instal a sub panel, you need a main panel (obviously) with a free space for a feed to the sub panel. Then you need a place to put the sub panel, wiring to connect the two (two hots, a neutral, and a bare ground wire), and a breaker put in the main panel to feed the wires going to the sub panel.My dad has basic electrical knowledge. A better question would be, what is involved with installing a sub panel? Any books or online guides that explain the basics?
Sounds like unsubstantiated urban legends to me. Conspiracy theory maybe? An un-named friend in "the industry" claims that some un-named company supposedly also in "the industry" is not doing something they should on the basis that you've made changes to a system that didn't have any impact on the reason for the claim?Some friends in the industry say that some companies are using this as an excuse to NOT pay claims, even if the fire was not electrical. Anyone know anything about this?
sub panels are usually much easier to install than main panels. a separate grounding rod might be the hardest thing to install, if your municipality requires it. a sub panel is kind of like just installing a big circuit breaker. it's greatly simplified relative to a main panel install in that de-energizing the main panel breaker stops all electricity flow, so all circuits on the house side of the main breaker are dead. add a two pole breaker of the size needed to the main panel, gauge the wire that connects that breaker to the sub panel correctly, black and red to the main panel breaker for the sub panel and then to the sub panel main lugs, white to the main panel ground bar and to the neutral bar in the sub panel and the ground wire to the main panel ground bar and to the ground bar in the sub panel. sub panel always gets separate ground and neutral bars.Thanks for giving it to me straight. I usually end up getting myself into projects that are more complicated that I'm prepared for!
I appreciate the fact that your getting an electrician but your shooting yourself in the foot so to speak. The benefit to a sub panel is to have a second set of breakers to run multiple equipment. It should look similar to your main panel but smaller. The type box you said he is installing is limited severely yet your paying almost the same labor as if you had the bigger sub-panel box installed. It sounds as if he don't understand what you need or he is setting you up to need him to come back in the future.
A 60-100 amp service panel is your best bet capable of having say 8-12 separate circuits in it. you want to have both 110 and 220 circuits in that sub-panel.
Not saying he is doing this but they will sometimes only do what you ask for even tough they know you could use something more. They do will do the minimum because they know you will likely call them out again which means more money since your paying for all of the same labor again.I will contact him again and try to explain what I'm looking for a bit better.
