I have a bed frame from about 1900. It feels like it looks somewhere between Art Nouveau and Arts & Crafts. I say this to indicate that it is antique, gorgeous, and in need of a repair I do NOT want to screw up.
As you can see, the rails are attached low on the headboard with screws above and below the rail. The problem is that the tall headboard and footboard flex these joints forward and back as you move the bed around, etc. A number of the screws no longer fit their holes—the holes have stripped out. I’ve tried replacing some with larger screws but that has turned out to be a temporary fix. I am looking for a “minimal damage” repair, suitable for antiques, that somebody with only slight repair experience can do.
The vertical member is 1.75” square, hard oak. The iron braces are about 1/4” thick. The old screws are something like #10 (shank is about 1/4” diameter), and 1 3/8” long. The next size up about fills the holes in the braces.
I saw a pocket-screw thread that mentioned drilling the hole out, gluing in a dowel, and starting fresh with that. I like that idea. I vaguely thought to fill the hole with a two-part wood filler (“bondo for wood”) I use for dry rot repair, but this sounds stronger and a far better solution for an antique.
The screw holes are about 3/4” center to center. If the screws are #10s or #12s, do I need something like 1/2” dowels? Which leads me to worry there isn’t going to be much original wood left between them. Harder to do, but would I be better off to chisel out the wall between, and insert a block that spans both holes? I have some wood saved from a 1930s armchair I could use for the plugs. Dry as bone and hard as iron.
If anybody has advice that will keep me from doing something stupid, I’d love to hear it.
