Hello
I have inherited a jigsaw black and decker which looks fairly unused but when I plugged it in it came on, I can see the lever on switch is sticking. I can pull it out but it does not easily go between on and off positions. Can I spray it with WD40 or open it and grease it do you think?
Thank you very much
Sorted and working
Thank you, I undid the side and took out the switch and just moved it around a bit, wiped around it and put it back. Now for the time being at least I can plug it in and the lever operates in the way that is should. Thank you for the encouragement, Carol
