I roughed out two cherry bowls this morning. This is the first time I have used the worm screw in the chuck. The first one went without any problems. When I went to reverse the the second bowl I could not unscrew it. I had the spindle locked and the chuck unscrewed. I knew I didn't have enough strength to hold the chuck and un screw the screw. I took the bowl and screw out of the chuck and drilled a series or holes around the worm screw and then used a crescent wrench to unscrew it. The hole gave enough relief to free the worm screw. Has anyone else experienced this. I drilled a 9/32 hole. The directions said 7 to 8 mm. I set my digital calipers on 7.5 mm and then changed the scale to inches and that was 19/64". I guess I could have gone with 5/16"
Tom
Tom
