I am finishing up a low-cost project (bedside table) that is made of plywood sides (inset w/ dadoes) and 2x3 studs for legs. The legs and some other trim pieces are very soft wood, so I'm guessing that the stain will soak right in and I'm not sure if this is good or bad. What I want to accomplish is a very smooth "satin" finish, with little or no gloss, and it will be a dark walnut type of stain.
1. Should I pre-treat the wood to avoid too much stain soaking in?
2. If so, what type of pretreating product?
3. What would be the best product to add last for the protective top coat that will not add a glossy look? (I'll need as much extra protection as I can get since this is soft wood)
Thanks so much for the help!
