I have some wood that I cut my self from a dead maple in the back yard. It has some nice spalting in it and will make a pretty cheese platter or small cutting board. Since spalting is effectively the result of a fungal infection in the dead wood, does the wood need to be treated in some manner before being used in a way that will contact food? Like I said, I produced this material myself so it hasn't been kiln dried or anything like that. Also, what do you recommend as a finish for something used for food? Just walnut oil or something similar?
Thanks for the help.
~Clark
Stay away from nut oils since some people are deathly allergic to them. Just use pure mineral oil for the finish. I am leery about using a spalted piece of wood for direct food contact. I would save the wood for another project.
Can't advise you on what finish to use but I can advise you that if your pic shows a glueup of unseasoned wood, you have made a mistake. You say it's not kiln dried, but is it air dried? If it's anywhere near freshly cut, it will now change size and most likely pop the glue joints.
Discussion Starter #4
Mineral oil is a good idea, I probably wouldn't have considered the possibility of allergies, I'll keep that in mind for future food related projects. Maybe I will skip the cutting board idea for this particular wood, just to be safe.
The picture isn't a glue up, just a clamp up because I wanted to get an idea of how it might look put together. The wood has been cut and air drying by my furnace in the basement for about 6 months, hasn't seemed to move too much. It still needs to be planed/jointed before I use it, I just did some quick "planing" with the table saw to get a better look at it.
Thanks, all.
