Dare I be so bold as to assert something such contrary to common belief? It appears that aluminum tape is only for security, peace-of-mind and bling. (all of which are important)
But as far as air leakage is concerned, I feel my tests exceed practical reasoning. Tests include:
The amount of pressure buildup was limited due to an issue with one of my blast gates, but it was enough to expose an issue with a tiny PVC-BlastGate connection leak on the other side of the garage. I feel that a pressure test is a bit ridiculous anyway, as it may actually push joints apart.
A more powerful dust collector may reveal different results. Mine is a 2HP Grizzly w/ a pleated filter.
VERDICT: I *will* seal my joints with aluminum tape for security and peace of mind (and bling). It's cheap, easy, and I'm tired of bumping things apart each time I modify something.
For reference, here's the full video including my story as it led me to these tests, then the tests (at least some), my concerns/caveats with the tests, and a smoker build.
I would be a fool to think that my tests covered all the bases and decided this one-and-for-all. If you found that PVC-PVC does need to be sealed, I'm interested to hear more about your setup.
- Negative pressure test: Localized smoke placed near each unsealed joint (tested around 30).
- Positive pressure test: Lines primed, sealed off, and additional smoke pushed in (low pressure)
- Positive pressure test: Lines primed, sealed off, then pressurized with an air compressor
